Activity Forums Adobe After Effects After Effects rotate multiple shapes
  • Walter Soyka
    March 28, 2017 at 12:51 pm
    I’d look to control the animation of the shapes with an image in a case like this — an invisible animated gradient that affects each layer’s rotation and scale. If you’re savvy with expressions, you can rig something with sampleImage(); otherwise, a tool like Ae Shader Effector will help you do the heavy lifting:
    https://aescripts.com/ae-shader-effector/
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Mitch Eaton
    April 20, 2017 at 1:16 am
    Awesome! works perfectly thanks !!!
