After Effects Renderfarm work in progress – help me troubleshoot por favor?
So I’m just starting to *attempt* to set up a qmaster render farm using After Effects CS3 on a small test setup before we try anything large. The issue is – it took well over 20 hours (somewhere in the neighborhood of 23-24 hours) to do what would take After Effects on its’ own no more than 5 minutes. I was only rendering out 1000 frames of a comp which didn’t have any heavy effects on it as well.
My current setup:
2 Intel Mac Pro workstations with 8cores, 8gb ram, osx 10.5.5 as Service nodes.
1 G5 Mac Pro workstation running as the cluster controller.The issues I ran into: numerous Unix Command Error: 7, Unix Command Error: 9 errors. Out of the 1000 frames that were set to be rendered, 15 got rendered out as psd’s (frames #: 1,111,333,370,481,518,556,630,667,703,740,778,852,815,963). The controller was trying to access aerender on the controller itself even though I don’t have any rendering services setup to run on the controller.
Any help or ideas?
