Activity › Forums › Adobe After Effects › After Effects rendered through AME gave jerky animation
  • After Effects rendered through AME gave jerky animation
    Posted by Syed Iqbal on December 31, 2016 at 12:09 am
    I imported png sequence into After Effects which was rendered at 29.97 fps from C4d and getting this jerky playback that you can notice after 4 secs onward.
    AE interpreted as 30 fps that I forced to actual 29.97 fps but still getting this problem and unfortunately I have no clue on this. Output file link is copied below, please come up with your suggestions if possible to resolve this.
    Output from AE using AME was H264 @ 29.97 fps
    https://www.dropbox.com/s/a3n1ed7aeoevgri/trinagle%20green.mp4?dl=0
    Thanks in advance.
    Syed
    Roei Tzoref replied 9 years, 9 months ago 2 Members · 2 Replies
  • Syed Iqbal
    December 31, 2016 at 6:46 am
    Just to clarify, I exported PNG sequence from C4D and imported that as footage in AE because I wanted to apply certain effects in After Effects.
  • Roei Tzoref
    December 31, 2016 at 5:44 pm
    I suspect this is a GPU rendering issue. try this – in the Queue panel in AME use “Mercury playback engine software only” as your renderer and not and not “GPU” and try again.
    Roei Tzoref
    After Effects Artist & Instructor
    ♫ Ae Blues Tutorials
