Activity › Forums › Adobe After Effects › After Effects render queue
  • After Effects render queue
    Posted by Arjen Bruinsma on March 27, 2009 at 4:01 pm
    I’ve been having a problem with After Effects CS3 now for a while. Although the program is running great, the moment I add a composition to the Render Queue I get a problem. When the composition is added to the render queue and I press ‘render’, nothing happens and the status goes back to ‘unqueued’.
    It happens everytime I try to output a render file.
    Can anyone help with this issue?
    Thank you very much!
    Arjen Bruinsma replied 17 years, 5 months ago 2 Members · 4 Replies
  • Jon Geddes
    March 27, 2009 at 8:10 pm
    Did you make sure you specified an output module and where it outputs to?
    If you didn’t manually specify those, particularly the output location, then it could have problems rendering.
    Jon Geddes
    Motion Graphics Designer
    http://www.precomposed.com
  • Arjen Bruinsma
    March 28, 2009 at 2:05 pm
    Hi Jon,
    Yes I did specify the output module and the output location. Still it won’t render and the render status goes back to unqueued.
    When I output the render via ‘File-Export’ it works, but soon as I try to output it in the Render Queue it doesn’t work.
    Hope you can give me further advice.
  • Jon Geddes
    March 30, 2009 at 5:31 am
    Maybe its having some kind of error.
    Can you check the error log? It usually creates a folder in the location of your project file with an error log.
    Does it give you any info in the render queue after you try and render?
    Are you able to hit render again after the failed attempt without bringing it back into the queue?
    Jon Geddes
  • Arjen Bruinsma
    April 8, 2009 at 8:22 am
    Hello Jon,
    Sorry for responding so late, but I wanted to reinstall AE first. Now I’ve done that, but it still won’t render.
    There is no info in the error log, neither does it give any info in the render queue. I can’t hit render again, unless I enable the render option: then the status goes back to queued. As soon as I press render, the status goes back to unqueued again.
    I have absolutely no idea what’s wrong. Could it be a problem with the RAM settings?
    Hope you can help.
    With kind regards,
    Aj Scott
