Activity Forums Adobe After Effects After Effects Render Issus
  • After Effects Render Issus
    Posted by Gina Porembski on March 2, 2012 at 5:36 pm
    For my job I have to do little animations in After Effects to show the higher ups. I use all high res images. For some reason they always look terrible and pixelated when I render. I render at lossless animation. Also it doesn’t render to the actual size that the movie should be, the latest file I am working on is 184×33, when I render it out, it is about twice the size, which I think has to do with why it looks so terrible because it’s being blown up, is there anything I can do to get this to render at the actual size of the file that I am working on? This also happens with bigger animations as well.
    Thank you
    Gina
    Gina Porembski replied 14 years, 6 months ago 2 Members · 2 Replies
  • Pierpaolo Ferlaino
    March 2, 2012 at 6:17 pm
    Are you using “Best Settings” as Render Setting in your queue?
  • Gina Porembski
    March 2, 2012 at 6:20 pm
    Yes! I think I figured it out, I was using some random size, when I used a preset it rendered beautifully!! I am guessing all these weird sizes is just throwing AE off. Thank you so much for your reply!!
