Activity Forums Adobe After Effects After Effects Ram Rendering Dead Stop.
  • After Effects Ram Rendering Dead Stop.
    Posted by Jimi Fox on September 8, 2011 at 3:04 am
    Hello:
    I’ve had an interesting event take place the last couple of days. Whereas, when rendering in ram a composition, which is 6:18, (as in minutes) long, the rendering came to a complete stop at 5:27. I revisited my steps assuming, I’m sure, that I had errored. Once again the project stopped before it’s completion. Only this occasion the stop occurred at 4:53. Now allow me to inform you that besides being a neophyt, of which, I’m sure you surmised. I have not encountered this problem before. However, I’ve been working on smaller projects spanning the lenght of 3 to 4 minutes.
    Finally, I do have a pretty Hefty computer. Its is Intel, Core i7-2600 CPU @ 3.40GH. My Ram is 16GB and the Cashe is 8GB. Hopefully someone out there in AE Jungle, recognizes the error of my ways and can guide me to a more positive conclusion.
    Thank you in Advance,
    Jimi Fox
    Jimi Fox replied 14 years, 12 months ago 2 Members · 4 Replies
  • Angie Taylor
    September 8, 2011 at 10:06 am
    It sounds like a memory issue. RAM is used in AE for caching frame of the RAM preview but also for undo and other things. If you are working in a high res comp with a high frame rate then your RAM can get eaten up very quickly. Here’s a link to a free video workshop that will help you ensure that you have optimised your memory settings correctly for CS5.5;
    https://partner.video2brain.com/angietaylor/courses.htm#/?c=1195&t=1
    hope this helps!
    cheers,
    Angie
    Angie Taylor animation & illustration for television, film, web and devices
    https://www.angietaylor.co.uk
    Twitter: theangietaylor
    Linkedin: theangietaylor
    https://www.facebook.com/pages/Angie-Taylor/118378194869002
  • Jimi Fox
    September 8, 2011 at 6:55 pm
    Thank You Mr. LaRonde:
    I truly appreciate your response. If I may sir, ask you this… Should I string together say a project whose time is in the area of 20 minutes and I’ve tied all the pieces together, rendering where I could to help the process along. … and added the audio mix created in Audition CS5, what is my expectation of producing a successful completed DVD product that in fact includes audio in-tack.
    I suppose that is what is confusing me. I did set up my rendering templates, yet obviously, I’m doing something terribly wrong that my output is silent, (my apologies to Charlie Chaplin).
    Other than being very old and forgetful, what is it that has not embeded itself sufficiently in my mind? Thank you in advance for your kindness and your time on this post.
    Thank You,
    Jimi Fox
  • Jimi Fox
    September 9, 2011 at 12:07 pm
    Dear Ms. Taylor:
    With considerable graditute, I thank you for both the input and the link. I find that my journey on this adventure, albeit made in earnest, has at times fallen into belly bursting folly. I however, find that my education has been well supported with the generousity of yourself and Mr. LaRonde.
    I have a clearer understanding of the processes and settings of which I have; thoroughly mangled mentaly in my interpetation, assesment and understanding. The help I have recieved, has not taken the curves out of my path, it has however, eleminated the debris from further building up. Always, a step in the right direction…
    Thank you for the assist and the link…that was a light that needed to be lit.
    Thank you,
    Jimi Fox
  • Jimi Fox
    September 9, 2011 at 12:21 pm
    Dear Mr. LaRonde:
    The information you and Ms. Taylor have thus provided, has turned that mirror into a window. I’m beginning to make sense of what it is I need to accomplish and what necessitates re-evaluating, re-adjusting and re-recording.
    I did so many things wrong in such a very short time, it is, astounding. However, with the input I’ve recieved, as well as, all that I continue to read, I can already see a successful journey henceforth.
    Already the rewarding results have lifted my desire to continue on with flourishing enthusiasum. I thank you, for that light!
    Sincerely,
    Jimi Fox
