Activity Forums Adobe After Effects After Effects Quicktime Rendering Problem
  • After Effects Quicktime Rendering Problem
    Posted by Jeffster on April 19, 2007 at 5:39 pm
    I have a fairly complex comp, all in 3d. It’s a HUD interface. I have a main comp with many precomps including status lights and a menu system etc. When I preview to RAM everything works fine. However, when i render to quicktime my target system wich sits in my main comp doesn’t render correctly. It’s almost like it is rendering the target system at half res. If i render out a targa seq or tif seq everything is fine. Has anyone else had any 3d issues with quicktime or seen anything like this?
    I am using After Effects 7.0.1.11
    Quictime 7.1.5
    86minutes replied 19 years, 5 months ago 3 Members · 3 Replies
  • Danny Princz
    April 19, 2007 at 11:56 pm
    how are you rendering your QT?
    what codec?
    are you rendering eith fields?
    anything else, that is different than your settings for tif or targa?
    who is that masked man…
    https://www.exposedideas.com/
  • Jeffster
    April 20, 2007 at 3:12 am
    codec none, highest quality, no fields, 23.976 fps
    It seems to be a rendering problem. I use quicktimes, all the time with complex comps and have never ran into this before. I have done all of the checks and balances, turning on and of layers, re rendering etc. to no avail. Image sequences have no problem.
  • 86Minutes Create COW Profile Image
    86minutes
    April 24, 2007 at 4:38 pm
    I’ve been having the same problem. Anything rendered with Quicktime (DVCPRO, Animation, Uncompressed, Blackmagic) looks like it’s at half resolution when imported into either Final Cut or AfterEffects. I’m using the same render que templates I’ve used for years and this is a new problem. When I render out as a TIF sequence (with the same Render setting as above) the image is good. I’m on a 3 year old dual 2.5 Mac. Any ideas on how to fix this?
    Thanks.
