Activity Forums Adobe After Effects After Effects Quicktime Preset not Rendering
  • After Effects Quicktime Preset not Rendering
    Posted by Valentino Laz on August 23, 2012 at 12:11 pm
    Hi I have had some trouble After effets(versions cs5/cs5.5/cs6) with Rendering any quicktime file on my PC(Windows 64-bit system).
    Any help with overcoming this problem I would much appreciate.
    I suspect it is the codecs on my pc… I have quicktime and itunes isntalled, I have allowed my firewall to allow communication. I have tried everything on this topic, but still no luck, I have never had this problem.
    Thank you.
    V
    Her
    Todd Kopriva replied 14 years ago 3 Members · 2 Replies
  • Keith Mcgregor
    August 24, 2012 at 3:57 pm
    Did you post this on adobe forums? Try that as well, maybe some engineer can help. Maybe it has something to do with your custom QT settings? I don’t know what your firewall has to do with it unless you are rendering across multiple machines.
    You shouldn’t be able to even see any codec your machine doesn’t have installed, so that shouldn’t be it. Post the QT settings, and in the meantime you can render out image sequences and compress them in another program to a different codec, or try the avi since you are on windows. And you have opened other qt movies and they work fine? Quicktime isn’t a codec, it’s a wrapper. The form of compression could be anything, it just has the .mov extension.
    Never seen that error before…
    sorry to not be of much help
    -Keith
  • Todd Kopriva
    September 20, 2012 at 5:47 pm
    See this article for suggestions for troubleshooting QuickTime:
    https://blogs.adobe.com/toddkopriva/2011/02/troubleshooting-quicktime-errors-with-after-effects.html
    After Effects team blog
