Activity › Forums › AJA Video Systems › After Effects problem with 1.2 drivers
  • After Effects problem with 1.2 drivers
    Posted by Chris Tomberlin on February 7, 2006 at 2:15 am
    Is anyone else seeing this problem with lines in After Effects at the 16bit composition setting? The 1.2 drivers have this problem, but reinstalling the 1.1.4 drivers makes the lines go away. This is footage captured in FCP with Kona2 10bit NTSC settings and imported into After Effects with the project set to 16 bits. The results are the same in AE 6.5 and 7.0.
    Chris Tomberlin
    OutPost Pictures
    Chris Tomberlin replied 20 years, 7 months ago 3 Members · 8 Replies
  • 8 Replies
  • Jeremy Garchow
    February 7, 2006 at 3:45 am
    Does this happen only with 10bit footage? I was working today in AE no problems, but not with 10 bit media. I can double check your setup (10 bit media and 16bit processing) tomorrow when I head in to the office.
    Jeremy
  • Chris Tomberlin
    February 7, 2006 at 2:59 pm
    Jeremy,
    I’m pretty sure this is only with 10bit stuff. I won’t have time until later today or maybe tomorrow to reinstall the new drivers and try them again with only 8 bit footage. Let me know what you find.
    Chris
  • David Battistella
    February 7, 2006 at 4:04 pm
    Please tell me how you pasted that into your post
    david
    Peace and Love 🙂
  • Jeremy Garchow
    February 7, 2006 at 4:12 pm
    You need to have server space or webspace available to post pictures. You then write in code which points to that picture on a website.
    You can read about it here:
    https://www.creativecow.net/articles/lindeboom_kathlyn/whipped_cream/
    Jeremy
  • Jeremy Garchow
    February 7, 2006 at 6:54 pm
    I’ve tried 8 ways to sunday, I don’t see what you see.
    Call AJA and they can help you out. It might be a faulty board. If it is, they can swap it out in a jiffy.
  • Chris Tomberlin
    February 7, 2006 at 7:09 pm
    It can’t be a faulty board if it only shows up with the new drivers and not with the old ones. Have you modified your After Effects preference file to “turn on” 16 bit capability for the v210 and 2Vuy codecs? And you don’t see the lines in a 16 bit comp? I’ve emailed AJA, but no response yet.
    -Chris
  • Jeremy Garchow
    February 13, 2006 at 11:35 pm
    I was able to get some time and repeat this issue today, after I modified the preferences in AE.
    Did you talk to AJA?
    Jeremy
    G5 Dual 2Ghz <> 4GB RAM <> FCP 5.04 <> Kona 2
    ATTO 42XS <> Huge Systems 4105 Fibre
    OS 10.4.2 <> QT 7.0.3
  • Chris Tomberlin
    February 13, 2006 at 11:47 pm
    I did indeed speak with AJA and was provided with a solution within a few minutes. As usual, there is a problem with the Apple 10-bit codec and the fix is to pull a component out of the 1.1.4 AJA drivers and use it with the 1.2 drivers. Contact AJA for the exact proceedure; it’s not dificult and in addition it might be good for them to hear from other people. What we all REALLY need to be doing is trying to get Apple’s attention. There is the previously discussed problem with the apple 10bit codec, there are gamma issues with that codec and a few other problems with plug-ins in a 10bit timeline in FCP.
    Chris
    OutPost Pictures
