Activity Forums Adobe After Effects After Effects – Premiere Pro workflow question…Hi,
  • After Effects – Premiere Pro workflow question…Hi,
    Posted by Mike Nagel on January 11, 2008 at 12:37 pm
    I have a basic question about workflow between AE and PP.
    I’m editing an acting reel for a client which deals with a lot of different footage and bits and pieces here and there.
    We already converted all the footage to DV-AVI – tweaking, color correction and effects are done in AE.
    Here’s the question that I’m thinking about:
    Should I work on all my footage in AE first and then import it into PP for editing OR should I edit everything the way I wanna have it and then import it into AE for the tweaking.
    Advantages for both options that come to my (newbie) mind:
    AE first then PP
    1. Final editing is done in PP which gives me flexibility if I wanna change things later editing wise
    2. PP exporting options are huge – don’t know if AE can compare to that
    3. could import to PP via Dynamic link which saves me the hassle of exporting each little clip from AE to a lossless format – as mentioned we have lot’s of different footage and little bits and pieces here and there
    PP first the AE
    1. if u apply a lot of effects, Dynamic link is a pain to scrub through the footage in PP because it takes so much time to render through the link – with exporting a final edited version from PP and then importing into AE would make things go a little bit smoother
    2. I would have more flexiblity if I wanna change any effects in AE
    What would u suggest ?
    Thanx for your help in advance !!
    Mike
    Mike Nagel replied 18 years, 7 months ago 19,816 Members · 1 Reply
  • Mike Nagel
    January 12, 2008 at 2:18 am
    I forgot to mention, the reason why I was thinking about doing AE first and then PP is, is that all of our footage needs to be tweaked in AE.
    So if I edit everything in PP first, then export to a lossless format, then import and start tweaking the footage in AE – how can I tweak footage properly that fades-in ?
    On some points we definitely gonna have longer transition, fade-ins etc..
    If I have the (lossless) output movie from PP I can’t tweak the footage that is aleady ‘waiting’ behind the fade-in transition…
    I see two options to this:
    a. wait till the footage has faded in, which means having partially bad and un-retouched footage in my movie, or…
    b. use Dynamic Link to bring in the PP project into AE – then I just need to hope that all transitions and effects I applied in PP are available in AE
    That was one of my main reasons why I thought about doing AE first and then bring in all the tweaked footage into PP.
    What would you suggest ?
    Thanx again for your help.
    Mike
