Activity Forums Adobe After Effects Expressions After Effects Position Expression
  • Dan Ebberts
    April 26, 2022 at 12:09 am
    I think we need more info. Please be more descriptive about what you’re trying to do.
  • Mirco Lanz
    April 26, 2022 at 7:18 am
    I want to build a Lightning Effect with “advanced lighting” The idea is that i have a fixed point for the beginning of the Lightning and the End is jumping to different tracked positions in the room.
  • Dan Ebberts
    April 26, 2022 at 2:58 pm
    This should randomly select the position of any layer except the one with the expression:
    minDur = .5;
    maxDur = 1.5;
    t = tPrevT = inPoint;
    seedRandom(index,true);
    while (t <= time){
    tPrev = t;
    t += random(minDur,maxDur);
    seedRandom(tPrev,true);
    L = [];
    for (i = 1; i <= thisComp.numLayers; i++){
    if (i == index) continue;
    L.push(i);
    fromComp(thisComp.layer(L[Math.floor(random(L.length))]).transform.position)
  • Mirco Lanz
    April 26, 2022 at 8:42 pm
    Thanks! I will try this tomorrow at work 🙂
  • Mirco Lanz
    April 27, 2022 at 5:06 pm
    I tested your expression today and it works wonderfully! Thank you very much! You have helped me a lot ❤
