Activity Forums AJA Video Systems After Effects – playback in monitor wrong
  • After Effects – playback in monitor wrong
    Posted by Missdivagirl on July 27, 2006 at 1:58 pm
    Bob,
    Not too long ago, you helped me solve a problem I was having with my set up. You figured out the wrong setting was chosen on the back of the monitor. After I switched to component, everything worked great. Playback for FCP and AE were normal again and I no longer had to switc h settings to print to tape as AJA had suggested. About a week after this solution, all my playback viewing from AE in the NTSC monitor is purple and pink. FCP and the beta deck alone is fine. I changed nothing but the button in the back of the monitor from RGB to component and all was fine. Any idea on which direction I should go to get AE playback back to normal? It was fine until about a week ago and nothing has changed, unless someone other than myself is playing with the equipment when I am not here… very unlikely though.
    Thank you,
    Angelina
    Cheers!
    Missdivagirl replied 20 years, 1 month ago 2 Members · 2 Replies
  • Jeremy Garchow
    July 31, 2006 at 3:26 pm
    Go into your AE preferences and make sure you have the correct output setting enabled. Perhaps you have an RGB setting enabled instead of a YUV setting. Select 525i 8 bit or whatever you are working in (dv for dv, 10 bit for 10bit, etc.)
    Jeremy
  • Missdivagirl
    July 31, 2006 at 5:16 pm
    Jeremy,
    That did it! You rock!
    Thank you!!!
    Cheers!
