Activity › Forums › Adobe After Effects › After Effects output to monitor
  • After Effects output to monitor
    Posted by Stig Olsen on May 3, 2012 at 1:45 pm
    Any smart solution for output to external monitor?
    My slots are filled:
    1. ATI Radeon HD 2600
    2. Mojo DX
    3. E-Sata for Raid
    4. P2 recorder card (AJ-PCD35)
    stig
    Lexi Rosy replied 14 years, 3 months ago 4 Members · 9 Replies
  • 9 Replies
  • Walter Soyka
    May 3, 2012 at 1:59 pm
    1. Replace Mojo DX with AJA or BMD board and upgrade Avid to v6 for open hardware support
    2. Cubix expansion chassis
    3. Upgrade to a computer with more slots
    4. Profile your computer monitor and use color management within AE
    Walter Soyka
  • Stig Olsen
    May 3, 2012 at 2:12 pm
    Hi Walter,
    I am in MC6 and I guess you understand that replacing Mojo DX with any of those boxes is not a proper solution in any way.
    Mac only has 4 slots if you dont expand with Cubix, with a cost of a new Z800.
    There is not a solution for us to work with the computer monitors.
    Have anyone tested this? – https://www.blackmagic-design.com/products/dviextender/
  • Walter Soyka
    May 3, 2012 at 2:24 pm
    Sure, I understand — but your problem is that you fundamentally want to stick 5 cards in a 4-slot box. Any solution is going to involve compromise.
    Assuming you want broadcast monitoring for color-accurate work, you can either use a supported video I/O card, or use color management with a high-quality, well-profiled display.
    The DVI-SDI device you link to will still appear as a computer monitor to the system.
    Walter Soyka
  • Stig Olsen
    May 3, 2012 at 2:39 pm
    Ok thank you.
    Its not for color control, but for more detailed VFX work on ungraded material.
    Stig
  • Walter Soyka
    May 3, 2012 at 5:39 pm
    [stig olsen] “Its not for color control, but for more detailed VFX work on ungraded material.”
    You can tear the comp panel off and drag it onto a second computer display. Cmd- will maximize the panel to the screen size.
    If that’s what you’re after, then the DVI/SDI adapter would work, but it is limited to standard video resolutions. If you’re working at 1920×1200 or higher (recommended, since the panel itself will still occupy some screen space) you’ll need regular ol’ DVI.
    Walter Soyka
  • Stig Olsen
    May 4, 2012 at 8:15 am
    Ok I did not think about that.
    What is ol’ DVI? Do I need more slots to use that?
  • Walter Soyka
    May 4, 2012 at 4:37 pm
    [stig olsen] “What is ol’ DVI? Do I need more slots to use that?”
    Sorry — good ol’ (shortened from good old) is an American colloquialism for the simple, tried, and true.
    I was just referring to connecting a second monitor to the second DVI output on your Radeon 2600.
    Walter Soyka
  • Jay Lloyd
    May 30, 2012 at 12:14 pm
    sorry to interrupt, I have been trying to get AE to output to external monitor.
    I have a decklink studio card install in an Mac Pro and a sony pvm 2541, they are connected via SDI.
    There is no 1080 25p settings, so I use 1080 50i. But the monitor is flickering very badly.
    Any solution??
  • Lexi Rosy
    June 25, 2012 at 2:18 pm
    I would recommend checking KVMSwitchTech. They offer a wide range
    of DVI Extender solutions. I have used a few of their DVI over Cat5
    units and they worked well for my application.
