Activity › Forums › Adobe After Effects › After Effects Optical Flares – Make only light show other layer help
  • After Effects Optical Flares – Make only light show other layer help
    Posted by Alex Stein on July 8, 2011 at 11:52 pm
    Hi, my problem is basic but difficult to explain when written down. I have filmed me and my mates and have put it into an AE comp. I want to create a spot light using Optical Flares but I only want the video to show where it’s shinning. I want the part that the light isn’t shinning on blanket out.
    Any ideas?
    Alex
    P.s. Sorry if this is not clear – like I said hard to explain!
    Alex Stein replied 15 years, 2 months ago 2 Members · 2 Replies
  • Greg Burrus
    July 9, 2011 at 10:11 pm
    I believe I was able to achieve the effect you are looking for, although I don’t have optical flares but you should be able to do something similar with it from what I know of it.
    What you can do is put the flare on black solid and set the track matte of your footage to luma. I did an quick example I can post if you need it.
    Hope this helps
    Greg
    https://mogra.g2bproductions.com/ – Blog
    https://g2bproductions.com/ – Portfolio
  • Alex Stein
    July 10, 2011 at 4:31 pm
    Thank you very much for this reply, just what I was looking for! Been trying to figure this thing out for ages!
    Thanks again,
    Alex
