Activity Forums Adobe After Effects After Effects on CRACK
  • After Effects on CRACK
    Posted by Charlie Hughes on January 23, 2008 at 8:30 pm
    I left, came back and suddenly my keyframes were all in a limbo between actual frames of my composition.
    I can theoretically adjust this i guess. But what gives? How did after effects shift every one of my keyframes to BETWEEN frames? What i mean is that i can’t put the position indicator on my keyframes anymore by clicking.
    Did i somehow change the frames per second resulting in incompatible frames in relation to the keyframes i had set?
    I don’t think i touched the FPS at all? Whaaat happened.
    Charlie Hughes replied 18 years, 8 months ago 2 Members · 2 Replies
  • Chris Heuer
    January 24, 2008 at 5:33 pm
    This doesn’t sound likely, but if you select all of your keyframes and hold down Alt/Option, then slide them left or right in the timeline, they scale relatively. This often results in keyframes sitting between actual frames.
    I doubt you “accidently” did that but… I haven’t posted in a while and I wanted to write something!
    Good luck! Chris
    Chris Heuer
    Freefall FX, LLC
  • Charlie Hughes
    January 24, 2008 at 6:45 pm
    This was the answer. Thank you. I had scaled the keyframes and only those scaled were effected by the weirdness.
    Thanks for your help. I’m glad you responded.
