After Effects : OCEAN
Hello,
I am working on a video that has a background composed of clouds and an ocean ( both made with fractals). The ram previews all look fine throughtout the video.
But every time I render, 5 minutes into the 8 minute video, the ocean stops moving. The ocean is keyed to continue moving, using the write in code part.
If anyone could hint at what could possibly be going amiss, I would be so darn grateful. This is a terribly tedious problem as none of the three 30 hour renders haven’t worked.
Thank you so much for any advice.
Sincerely,
Bea
