Activity Forums Adobe After Effects After Effects not recognizing camera in render?
  • After Effects not recognizing camera in render?
    Posted by Brian m. Finn on February 24, 2016 at 1:42 am
    I have 2 cameras in a comp… the camera I am using is turned on and is above the other camera… the camera I am not using is turned off AND they do not overlap. The camera I am using is definitely above all the layers in use. I see the camera in my comp window, but when I go to render, it doesn’t recognize it as the active camera. I even tried moving the camera all the way to the top of the comp, but no success. When I switch between the active camera and my comp camera under the window, I see the difference, but can’t understand why the render will not see my comp camera as the active camera.
    Brian m. Finn replied 10 years, 6 months ago 2 Members · 2 Replies
  • Tudor “ted” jelescu
    February 24, 2016 at 8:15 am
    Do you have the camera you want to render selected as active under the comp window as you render?
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Brian m. Finn
    February 25, 2016 at 3:26 am
    I’ve tried both… in this comp, the camera I want is called “camera 8” (even though there’s only 2 cameras in the comp, like I said the other is turned off)… usually I can render fine when the camera I am using is selected under the comp window. I tried rendering once with camera 8 selected… and again with active camera selected and the same problem occurs.
