Activity › Forums › Adobe After Effects › After Effects + Mocha – face replacement problem
  • After Effects + Mocha – face replacement problem
    Posted by Agnieszka Sosen on March 4, 2012 at 3:27 pm
    Hello,
    I’m doing a face replacement task in After Effects CS5.5 and Mocha plugin. I’m following the
    tutorial by Lesterbanks:
    https://lesterbanks.com/2011/06/face-replacement-using-after-effects-mocha/
    I’m trying to replace the face of the guy from the movie with my own face.
    I have the layers as in the tutorial: bg (the movie with the guy) face (vid with my own face)
    and track which is copied info (mapped face) from Mocha plugin.
    I do all the steps as in the tutorial but in the end my face does not follow the face of the guy
    (his face moves a bit and there is a slight zoom following – my face should also grow bigger as
    the zoom takes place, but it stays the same size as in the beginning).
    Here are screens how does it look on my PC:
    https://img829.imageshack.us/img829/9991/66090705.jpg
    https://img525.imageshack.us/img525/8934/58871993.jpg
    So, as you see on the second screen, the face doesn’t follow the actor in the correct way.
    I think I did everything the same as in the tutorial, so I have no idea why this is not working.
    I need help in detecting what went wrong here.
    Thank you very much in advance.
    Ross Shain replied 14 years, 6 months ago 3 Members · 6 Replies
  • Chris Buttacoli
    March 6, 2012 at 3:16 am
    It seems that you did not tick the scale parameter in the mocha track. I don’t see any keyframes in your AE comp.
  • Agnieszka Sosen
    March 7, 2012 at 7:11 pm
    It is not the problem with the scale parameter – I ticked it and pasted the whole tracking data from Mocha for both the guy’s face and my face.
    I pasted them again to make sure and it still doesn’t work.
  • Ross Shain
    March 8, 2012 at 5:36 pm
    You may need to delete the anchor point keyframes.
    If you want o get in touch with mocha product support specialists, log your case here: https://www.imagineersystems.com/contact_form
    Best,
    Ross
    Ross Shain
    Imagineer Systems
    http://www.imagineersystems.com
  • Agnieszka Sosen
    March 11, 2012 at 1:32 pm
    Thanks for the contact.
    Could it be the case that the when 2 videos have different dimensions/resolution/fps they don’t work properly together?
  • Agnieszka Sosen
    March 11, 2012 at 4:35 pm
    Ok, I located the source of the problem – I had to time stretch the layer with the pasted mapped data from Mocha.
    The face didn’t follow the actor fast enough (it was lagging behind), so I changed the ‘stretch’ parameter from 100% to around 40% and it matched the movement appropriately.
    Although, I don’t have the idea why I had to change the stretch – the tutorial didn’t mention it. Could the fps be the source of this? (the movies both have 25 fps, but the mapping in Mocha was done in 10fps)
  • Ross Shain
    March 11, 2012 at 7:20 pm
    Yes – this is the issue. mocha and AE project frame rate and image dimensions “always” have to match to insure the data lines up properly.
    Best,
    Ross
    Ross Shain
    Imagineer Systems
