Activity › Forums › Adobe After Effects › After Effects Layer Markers.
  • After Effects Layer Markers.
    Posted by Deyo Glines on July 2, 2013 at 7:50 pm
    I’ve tried to search this out, but maybe I’m wording it wrong. I want to place a marker at a point inside of a frame, but it snaps to the beginning or end of the frame only, There is a specific accent that I need to hit mid frame. In Pro Tools it’s called “Slip” mode where you can get right at the point of interest to edit. Is there a similar function for After Effects to mark inside of a frame? Thanks.
    Deyo Glines replied 13 years, 3 months ago 2 Members · 2 Replies
  • Joseph W. bourke
    July 2, 2013 at 10:04 pm
    I think that it’s because they are “frame markers”, you cannot mark anything but a frame. I think the only way you could do this is by changing the frame rate of the clip, which might not be a good idea. Might a Composition Marker be able to get you a workaround on this? I don’t know whether they snap to the frame as well, but I would assume that they would, since the basic unit of the Composition is the frame, after all.
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
  • Deyo Glines
    July 2, 2013 at 10:34 pm
    Thanks Joe,
    Yes the comp marker snaps as well. I thought thought I’d just throw this out there incase there was some kind of slip function for the wav files. I fussed it close enough for RnR [ which is what it is].
