Activity Forums Adobe After Effects Expressions After Effects keeps warning of a problem but expression still works
  • After Effects keeps warning of a problem but expression still works
    Posted by Josh Smith on September 17, 2015 at 8:39 am
    I have an if expression where x position reaches a certain point then it starts a rotate. I have the positions dimensions separated on the layer using position. Everything works but it still gives warning “error at line 0” and that the problem’s “object of type Layer found where Number, Array or Property is needed”
    if
    (thisComp.layer(“5”).transform.xPosition<1391.0)
    -time*100
    Josh Smith replied 11 years ago 2 Members · 2 Replies
  • Dan Ebberts
    September 17, 2015 at 4:07 pm
    Your expression has to always provide a value, which yours doesn’t if xPosition is greater than 1391.
    Adding something like this to the end should fix it:
    else
    value
    Dan
  • Josh Smith
    September 17, 2015 at 4:19 pm
    Ah as simple as that! Thanks Dan
