Activity Forums Adobe After Effects After Effects keeps freezing when I use the timewarp effect.
  • After Effects keeps freezing when I use the timewarp effect.
    Posted by Ryan Elder on April 1, 2020 at 5:48 pm
    Everytime I try to apply the timewarp plug in, and then add motion blur to an effect, which is what I want, I will then hit the play button so it can go through the frames and add it. But every time I do this, the program always freezes after a few frames. It never seems to unfreeze so I have to shut down and try again, but it keeps on freezing whenever I attempt the timewarp.
    Does anyone know what the problem could be? Thanks for any help. I really appreciate it :).
    Ryan Elder replied 6 years, 5 months ago 2 Members · 3 Replies
  • Richard Garabedain
    April 1, 2020 at 8:57 pm
    timewarp has its onw motion blur effect are you using that? How long is your video. if its too long that could be the problem…
  • Ryan Elder
    April 3, 2020 at 5:50 am
    The clip I want to add it to is six seconds. However, I seem to have found a solution. If I pre-compose the clip, then it seems to work. Does precomposing do anything to it that allows it work?
    I am using the motion blur effect in timewarp, yes.
  • Ryan Elder
    April 3, 2020 at 8:36 am
    Actually it’s back at it again now, now that I have reopened it to continue. Pre-composing is no longer helping and it will freeze any time I try to add an effect and then play through the frames.
