Activity › Forums › Adobe After Effects › After Effects keeps crashing????
Posted by James Carver on April 17, 2016 at 10:17 pmAfter Effects keeps crashing today for some reason..says I am out of application memory….has happened 3 times in the last 20 mins and I haven’t had this issue before. Any idea what could be causing this issue?
I’m on an iMac
32 GB 1600 MHz DDR3
3.5 GHz Intel Core i7
NVIDIA GeForce GTX 780M 4096 MBJames Carver replied 10 years, 3 months ago 3 Members · 13 Replies -
Soham Jani
April 18, 2016 at 12:25 amNot sure about this, since I don’t have a Mac, but try this. I found this thread which might help. https://forums.creativecow.net/thread/2/924394
Also, did you try Googling it?
\”It\’s all around us Neo, temporary constructs of time…..\”
James Carver
April 18, 2016 at 3:36 amThanks, not sure what “secret menu” dude was talking about but I just cleared my cache and hopefully that’ll solve the issue I couldn’t find anything specific through google about this other than that. Not sure if there is more to it or not?
Soham Jani
April 19, 2016 at 3:55 pmSorry for the late response, but did it help? I mean I’m not sure what exactly could be doing this, but you may have to uninstall and reinstall AE…maybe.
Hanna Dean
April 19, 2016 at 7:59 pmgoogle factory reset after effects , something like hold ctrl+shift and click the exe it will boot as fresh.
google it
James Carver
April 20, 2016 at 4:17 amThanks it did spark a thought in my mind to clear my cache in after effects and it hasn’t crashed since (fingers crossed) so thanks!
iMac 27\” Late 2013
32 GB 1600 MHz DDR3
NVIDIA GeForce GTX 780M 4096 MB -
James Carver
April 20, 2016 at 4:18 amthanks if it does it one more time I will do that next.
iMac 27\” Late 2013
32 GB 1600 MHz DDR3
James Carver
April 24, 2016 at 7:01 amApparently the memory crash I keep having is not uncommon and has been going on for several years with others having the same issue and the only resolution seems to be wait for Adobe to put out a bug fix….has anyone gotten this error talking about being unable to allocate memory and to either decrease memory allocation or go out and buy more RAM??? This message comes up several times to the point I have to keep force quitting the program :/
iMac 27\” Late 2013
32 GB 1600 MHz DDR3
Hanna Dean
April 24, 2016 at 10:56 am1: type small portion of that message in google your problem will be solved because this error is covered by adobe and there wil be no fix , it is not an application error its your pc.
2: what ram do you have , maybe your pc ram is not enough , i have 16gb ram and when i run after effects it can climb to 3gb or max 8gb usage , depending on what you do.
James Carver
April 24, 2016 at 2:26 pm1) I did this before posting. Also did you actually see that official response from adobe or are you just assuming that? I have seen Adobe mention that it is a bug and they have issued an update for it, when the person in the forum mentioned it may be something they’re doing an Adobe rep specifically said it was a bug and not a user error….problem is this patch was released with an earlier version of AE.
2) I have 32GB of RAM, specs are in my signature on every post. This particular project I’m doing something way less labor intensive than what I usually do which is boggling.
iMac 27\” Late 2013
32 GB 1600 MHz DDR3
