Activity Forums Adobe After Effects After Effects importing 1080p MP4 at wrong dimensions
  • After Effects importing 1080p MP4 at wrong dimensions
    Posted by Nettie Tien on January 13, 2015 at 3:53 am
    Hi there!
    I’ve recently received a 1920×1080 H264 MP4, 90fps, 22.7Mbps bitrate, no audio. The person I received it from rendered the original file from Unreal Engine 4 as a 220GB AVI, then transcoded in Freemake to the H264 MP4. After Effects is importing this file as 16×160, 90 fps. I am able to play the MP4 in VLC, but not Quicktime or Compressor. Adobe Media Encoder also thinks the file is 16×160. See below screenshots from After Effects and Adobe Encoder for reference.
    Any ideas why this is happening? I have tried poking around the forum and haven’t found the same exact issue.
    Thank you for your help!! 🙂
    Cow Boy replied 11 years, 8 months ago 3 Members · 4 Replies
  • John Cuevas
    January 13, 2015 at 8:25 pm
    That’s really strange, not sure why it’s happening and only solution I have is a hail mary, but try changing the extension from .mp4 to .mov—-it should play from QT then, not sure if AE will work with it better. Also, go to “help” and make sure you are running the latest version of after effects(Updates…).
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Nettie Tien
    January 14, 2015 at 2:05 am
    Thanks for the suggestion John!
    Unfortunately, QT doesn’t like it 🙁
    I’m currently using AE CS6 11.0.3.6. I’m hoping I don’t have to upgrade to CC just to use this file?
  • John Cuevas
    January 14, 2015 at 2:47 pm
    Post on the main AE forum, it’s a little more trafficked and there are some people who know the nitty gritty of codecs better. Also, include, AE version, computer info, software OS and codec information.
    Thinkck.com
  • Cow Boy
    January 28, 2015 at 8:33 am
    Although After Effects like CS4, CS5, CS6, CC supports MP4 natively. there are many video, audio codec problems occurred while importing MP4 video into AE in that MP4 can be wrapped with many different codecs.Google and you will find more information.Good luck!
