Activity Forums Adobe After Effects After Effects image sequence issues
  • After Effects image sequence issues
    Posted by Graeme Morgan on November 12, 2010 at 5:19 am
    So I recently ran into this issue and had a quick fix. I was wondering if anyone has a proper fix.
    I am doing a 3d motion track of some footage- then adding some C4D elements. I had to create a mocha shape roto for some foreground objects so they sat in front of the C4D elements.
    Everything was going fine- until i tried to export the mocha shape data to after effects. It kept coming in a little slower than the video with the C4D elements. It was the exact same clip, same size, same frame rate, eveyuthing was the same- EXCEPT I had a PNG image seq from C4D and I used my original vid file in mocha. However, they should have been playing back the same.
    I did a test and exported the video file to PNG seq in after effects because that is what I started with as my background layer in C4D. I re-imported the image sequence and the frame rate was off. The image sequence was plying at roughly 220 fps, while the original clip was 281 fps. I tried exporting at 24fps rather than 23.976- but I ended up with the same results. I played around with different export options and gave up. I did not want to redo all of the mocha roto work, so instead I did a time adjustment on the image sequences so they matched the original file and the mocha shape info.
    It was a quick and dirty fix and was wondering if anyone knows what the real problem was. I tried all of the main steps, from deleting plist files to creating a new after effects file to restarting my computer. This is bothering me because I know there is a proper fix. Any help would be great. Thanks.
    Graeme Morgan replied 15 years, 8 months ago 2 Members · 2 Replies
  • Adriano Moraes
    November 12, 2010 at 12:13 pm
    Hi there!
    Did you check your import settings in the preferences to see if it matches your frame rate?
    Just throwing it out there.
    Cheers.
    ninguem
    ////https://cargocollective.com/ninguem/
  • Graeme Morgan
    November 12, 2010 at 6:38 pm
    So that’s the solution to that mind-bender. That was the issue- I probably should have checked that. Thanks for the help.
