Activity › Forums › Adobe After Effects › After Effects “Hide” Bug
  • Steve Roberts
    November 28, 2006 at 7:20 pm
    a) double-click on the project name at the top of the window
    b) use cmd-tab to switch between apps
    That’s what I’ve found, anyway. 🙂
  • Lloyd Alvarez
    November 29, 2006 at 1:54 am
    Until this bug is fixed, Minimize instead of “hide” after effects by clicking the yellow button on the top left of the window.
    If you find that you are stuck with a hid AE, you can force quit it while inducing an automatic save of your project by going into the Terminal and typing:
    ps -xc
    note the PID number for AE
    then type:
    kill -SEGV xxx (replace the xxx with the PID for AE)
    it will save an incremental copy of your project in the same place where the last version was saved.
    hope that helps,
    -Lloyd
