Activity Forums Adobe After Effects after effects file sizes
  • after effects file sizes
    Posted by Brian Kelsey on August 11, 2009 at 7:18 pm
    Why are my After Effecs files so big? For example, (to test) I dropped in a quicktime video file that was 74 MB.
    I did nothing but render to a quicktime file using the default animation compression. I didn’t change any settings. After it rendered, it was 3.5 G’s! What am I doing wrong?
    OSX 10.5.6
    2.93 Ghz Intel Core 2 Duo
    4 GB RAM
    Glyph 1TB external Hardrive
    Todd Kopriva replied 17 years ago 2 Members · 3 Replies
  • Todd Kopriva
    August 11, 2009 at 7:43 pm
    You have “transcoded”—you effectively converted your movie to being encoded by the Animation codec. The Animation codec is good at preserving image information; it’s not good at making files small.
    Your original movie was encoded using a codec that was good at keeping files small. After Effects unpacked this information to make a full image. You just didn’t tell After Effects to stuff the image information back into a highly compressed form.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
  • Brian Kelsey
    August 11, 2009 at 7:59 pm
    Very good information, thank you. Which compression would you suggest? I am using AECS4. It is HD 1920×1080 video for television…thanks!
  • Todd Kopriva
    August 11, 2009 at 8:06 pm
    This is a huuuuuuuge question, and frequently asked.
    Here is the very simple answer:
    If you’re encoding for final delivery, then you need to ask your client what they want.
    If you’re encoding for intermediate or archival purposes, then you should use a lossless codec. For 8-bpc work, I like QuickTime movies encoded with PNG or Animation, depending on the kind of imagery.
    Here’s a link to a section in After Effects Help about compression: “Encoding and compression options for movies”
