Activity Forums Adobe After Effects After Effects file and rendering problem
  • After Effects file and rendering problem
    Posted by George Tsirogiannis on August 23, 2010 at 7:03 pm
    Hello, I’m facing a problem with After Effects CS4.
    I was working for 4 days on a short film shooted with Canon Legria/Vixia HF200 in AVCHD format. I edited it on Premiere Pro CS4 and then imported the project into AE in order to add some effects and color correction. While everything was OK, suddenly a video file got corrupted. Then, another one got corrupted.
    I tried to fix the problem by taking from a first “trial” render the frames that got lost and placing them on the projec where needed.
    Then, I started rendering the video again. In some point, After Effects told me that it “can’t read frames” from a video excerpt (but the file is not damaged!).
    How can I fix this?
    My system is an Intel Core 2 Duo 2.5 GHz processor, 2 MB RAM, a 500 GB local disk and 3 external disks (if you need anything else, just tell me). The footage is on an external hard disk and I set the final video to be rendered on the local disk.
    Thanks in advance!
    Roland R. kahlenberg replied 16 years, 1 month ago 2 Members · 1 Reply
  • Roland R. kahlenberg
    August 24, 2010 at 4:02 am
    Re-digitize/ingest the affected clips from within PremierePro. The replace the clip in AE. It’s a quick way to sort problems such as this.
    HTH
    RoRK
    Sell your AEPs with broadcastGEMs’ DVD series of templates. Click here for more
