Activity Forums Adobe After Effects After Effects EXPORT pro res422 hq PROGRESSIVE
  • After Effects EXPORT pro res422 hq PROGRESSIVE
    Posted by Gerald Ruppen on April 14, 2011 at 4:24 pm
    Hello Guys
    Can me help somebody. I have a project in dvc pro hd 1080i25p. I let the footage always interpret as
    DVCpro HD 1080 25p
    How do I interpret this file type in After Effects???
    If I chose Dvcpro HD 1080 25 then the pixel aspect ratio shows up
    HDV1080/DVCPRO HD 720 (1.33)
    My Question is Do I lose My original width 1440 and Height 1080 ??? and Converts all to an aspect Ratio based on 720 pixel???
    And How does It function wenn I mark the checkbox (Lock Aspect Ratio to 4:3 (16:9))
    by choosing the Pixel Aspect Ratio Box DVC PRO HD 1080 (1.5)
    Does this work has anybody experience ??
    Thanks and greetings
    Gerald Ruppen replied 15 years, 4 months ago 61,532 Members · 3 Replies
  • Gerald Ruppen
    April 14, 2011 at 6:02 pm
    Thank you for the answers
    It does fit properly with HDV 1080 the bos shows the HDV /DVCpro 720 an it looks fine. By dragging the footage to make new comp I has exact these settings.
    I thougth It has something to do with my interlaced / progressive problem in fcp. It always shows odd frame dominance . So I think ae exports interlaced.
    The odd framerate dominance disappears when I use Prores 422 Lt. But When I use the same settings with Prores 422 hq it is an odd dominance.
    But the Lt has a bigger compression I dont want that because I dont want to lose quality before I make the color grading.
    I dont know why
  • Gerald Ruppen
    April 14, 2011 at 7:43 pm
    Thanks for your answers
    After Effects interprets every thing correctly. The drag new composition works as well. The Problem is fcp
    It interprets that wrong. I ll change the field dominance of none for my progressive project.
    Thanks a lot for your advice.
  • Gerald Ruppen
    April 16, 2011 at 10:55 pm
    Such nasty things are always time consuming. I hate that. I lost about a day. I have one more Question can I interpret my raw material as 1080 i Its the same at the end?? On big screen and things like that??
    Because mx matrox mxo2 hasnt a 1080 25p Codec only 24p….
