Activity › Forums › Adobe After Effects › After Effects Error: Plug-in could not be loaded (1114)
  • After Effects Error: Plug-in could not be loaded (1114)
    Posted by Rebecca Apodaca on November 6, 2018 at 5:25 am
    This error randomly happens. Some days it doesn’t while other days it does but whenever I try to add an effect/plugin to a video or solid I’ll sometimes get an error saying the plugin could not be loaded.
    I’ve already tried reinstalling the plugins but that didn’t work. This only happens for some plugins as not all of them get this error. The ones that do are VC Sabre, VC Twitch, and Magic Bullet Colorista (strangely the other MBL Suite Plugins work fine.)
    My specs are:
    Ryzen 1800x 8core 3.6ghz
    GTX 1070 founders edition
    WIndows 10 home
    32gbs corsair vengance ddr4
    and the after effects version I’m using is CC 2018
    Mark Whitney replied 7 years, 10 months ago 2 Members · 1 Reply
  • Mark Whitney
    November 7, 2018 at 4:31 am
    When this starts happening, have you tried simply doing a system log off then back on?
    Sounds more as if something system-wise has tripped over it’s own shoelaces so to speak and will continue to trip up other things until all gets back in line.
