Activity Forums Adobe After Effects After Effects error: opening sound component (-2166)
  • After Effects error: opening sound component (-2166)
    Posted by Aria Slade on March 16, 2006 at 10:40 pm
    I exported a quicktime file out of premiere, then imported it into after effects, with the intention of converting it to an .avi file. However, when I try to do so, this error message keeps popping up… what am I doing wrong?
    Aria Slade replied 20 years, 6 months ago 2 Members · 3 Replies
  • Tony Bartolucci
    March 17, 2006 at 1:43 am
    What format is the sound in? AE really only likes wav.
  • Aria Slade
    March 17, 2006 at 3:12 am
    the audio is imported from premiere, as part of a file.
    the sound settings for exporting from AE are:
    Compressor: None
    Rate: 22.050 kHz
    Use: Mono
    these are also the default settings, which don’t work
  • Aria Slade
    Compressor: None
    Rate: 22.050 kHz
    Use: Mono
