Activity Forums Adobe After Effects After Effects doesn’t complete Renders.
  • After Effects doesn’t complete Renders.
    Posted by Michele Poggi on March 26, 2011 at 10:15 am
    Hi Guys.
    I’m having some issues in the last days working on my workstation (https://forums.creativecow.net/thread/2/997730).
    I have sadly a real urgency about finishing this work, and now even another problem came up. When Rendering a composition, AE suddenly stops at some frames, even without any warning or error. In the link I posted above there also are my PC’s specs, I really hope to solve this stuff asap, and sorry for my nervousism.
    “Cinetica Video” post-producer.
    Brian Charles replied 15 years, 5 months ago 2 Members · 4 Replies
  • Michele Poggi
    March 26, 2011 at 10:53 am
    It’s getting worse, crashing as long as I hit “render”.
  • Brian Charles
    March 26, 2011 at 4:11 pm
    What happens when you remove the gen arts effects?
    Have you tried resetting the After Effects preferences to their defaults? (Hold down alt+Shift+Control when you launch After Effects)
    Have you adjusted the “Secret” Preferences to purge every x number of frames on render?
  • Michele Poggi
    March 27, 2011 at 1:00 pm
    I think the problem is exactly in the Sapphires, so I still didn’t try to uninstall them because it actually IS what I need to finish this work. I will try resetting the preferences but for now I discovered something extremely weird.. I get a lot less problems (I get them, but fewer) if everytime I have to preview or render I move ALL the layers in a new comp. I don’t really understand “technically” how this helps but actually.. It does, a little.
    I’m really interested about the “secret” option you mentioned as it could be something I unaware of, can you englight me? ;] Thanks for the help, really.
  • Brian Charles
    March 27, 2011 at 2:40 pm
    If press the Shift key when you select Preferences > General from the menu, Secret preferences that affect rendering and memory management are revealed.
