Activity Forums Adobe After Effects After Effects does not render anything URGENT!!!!
  • After Effects does not render anything URGENT!!!!
    Posted by Charles Boucher on June 29, 2012 at 10:14 pm
    Hey guys,
    About 2 days ago I was working on my file as usual (with no changes whatsoever to my software or hardware) and After Effects suddenly refuses to render my video and does not even go past one single frame, it will not render movies, image sequences, anything, it does not render period.
    when I click on stop it gives me this message:
    I have not changed any settings on my computer or After Effects and rendering this specific file worked fine before this random occurence a couple days ago, other files render work so something is wrong with this file specifically.
    The project I am working on is a rotoscoping animation, I have used the Rotobrush on some MOV files, along with Particular Trapcode, and some effects such as Glow and Blur, nothing fancy.
    Here’s my technical info , hopefully it’s enough detail:
    After Effects CS5.5
    Mac OSX 10.7.4
    Memory 16GB 1333 MHz DDr3
    3.1 Ghz Intel Core i5
    MOVIE FILES INFO:
    50fps
    1280×720
    h.264
    Linear PCM
    16-bit little-endian signed integer, 4800HZ (stereo LR)
    File sizes range from 1.33Gb to 500mb (I can’t compromise on quality as this is a big project)
    Is there anything else you need to know? my deadline was yesterday and this is for a live show next week, any help would be greatly appreciated.
    Also audio’s not a big deal as I’m not using it, here are some screenshots of my project settings.
    Charles Boucher replied 14 years, 2 months ago 4 Members · 9 Replies
  • 9 Replies
  • Charles Boucher
    June 29, 2012 at 11:02 pm
    PS even my backups from before this issue occured are now showing the same problem…
  • Charles Boucher
    June 30, 2012 at 6:52 am
    Please guys I could really use your advice on this.
  • Charles Boucher
    June 30, 2012 at 7:06 am
    I’ve just tried ‘collect files’ it says the file is still corrupted
  • Perry Kroll
    June 30, 2012 at 2:30 pm
    Have you tried rendering to a different drive or location within the same drive? Try both of those things. I have had similarly confusing errors over permissions problems before.
  • Charles Boucher
    June 30, 2012 at 3:20 pm
    Just tried a different location, and from another drive.
    None of these work.
  • Erik Jägberg
    June 30, 2012 at 5:45 pm
    Have you tried to create a new project and importing the problem project into that one?
  • Charles Boucher
    July 1, 2012 at 12:12 am
    I would but I don’t think the rotobrush strokes would transfer to a new project, I will give that a shot though.
    I’m not going to restroke everything though as this was the long and painful part. :p
  • Thomas Leredu
    July 2, 2012 at 10:20 pm
    If still looking for help, you could try to reset After Effects settings to default by pressing cmd+alt+shift at startup.
  • Charles Boucher
    July 3, 2012 at 8:21 am
    That doesn’t work, and nothing happens when I hold these keys at the same time during the startup.
