Activity › Forums › Adobe After Effects › After Effects CS6 (on Mac) won’t render the composition
  • After Effects CS6 (on Mac) won’t render the composition
    Posted by Jared Boice on August 11, 2013 at 12:38 am
    Having some strange behavior, on brand new top-of-line iMac with latest OSX build (10.8.4)
    First of all, If I want to render-preview a certain area, I’m used to just hitting spacebar and then when I’m satisfied with the length of the green bar/rendered area, I hit space bar again to stop and then start over to view in real time.
    Now it seems like I have to keep pushing spacebar every few frames (when at Full Resolution, less often in draft qualities)
    Then, when I’m ready to add to render queue, it doesn’t appear to export the work area bar, but instead only renders out what was render previewed (with the green progress bar). Either way, I get a premature ending to my render. Never something I had happen on CS4
    I have the most recent updates for AFX as of yesterday
    Ericbowen replied 13 years, 1 month ago 4 Members · 5 Replies
  • Mathew Fuller
    August 11, 2013 at 2:55 am
    Always use zero on the number keypad section on the keyboard to preview… Dont use spacebar.
    A screenshot of your render settings would help.
    My Work:
    https://www.morecompletefx.com
  • Jared Boice
    August 11, 2013 at 4:05 pm
    Dave, I’m not referring to a RAM preview. I’m talking about what I call a “render preview”… don’t know what it’s officially called, but when I’m just previewing stuff on the timeline. But even a RAM preview will only play as far as the green line as been previously rendered. Also… I don’t have the numeric 0 on my keyboard, so is there a keyboard shortcut for that on the smaller keyboards or do I have to click the actually button?
    In addition to that, my “add to render queue” renders don’t render out the entire timeline.
    What settings in particular do you want to know?
    Here’s what I got:
    Previews:
    Adaptive Resolution limit 1/8
    Zoom Qualityi: Faster
    Color Management: More accurate except RAM preview
    preview: 5 frames
    Audio Preview: 30 seconds
    Media & Disk Cache:
    Enable Disk Cache checked
    Max Disk Cache Size: 100 GB
    Write XMP unchecked
    Create Layer markers checked
    Memory & Multiprocessing:
    Installed RAM: 16 GB
    RAM reserved for other applications: 4 GB
    reduce cache size checkbox is off
    render multiple frames simultaneously is off:
    Installed CPUS (processor cores): 8
  • Jared Boice
    August 11, 2013 at 4:28 pm
    Also, in some instances even when I attempt a RAM preview (which I discovered is control-0) sometimes I get an error message telling me RAM preview needs 2 or more frames to playback…..one example of when it does this is when I move the work area to a new place.
    It’s just giving me all kinds of flaky issues. I even just tried turning off disk cache and that doesn’t seem to help either.
    I’m really not doing a whole lot of super processor intensive things at this point. I’m using Twitch on a logo (video co-pilot plug-in) on a pre comp….and one optical flare. That’s it. Nothing crazy going on. No 3D cameras even
  • Todd Kopriva
    August 12, 2013 at 10:54 pm
    That’s usually because you have the From Current Time option enabled in the Preview panel, but the current time indicator is outside of your work area (or at the end of the composition or work area).
    After Effects team blog
  • Ericbowen
    August 13, 2013 at 10:28 pm
    https://helpx.adobe.com/after-effects/using/memory-storage1.html
    Change Render Multiple frames to on and set ram per thread/core to 1GB.
    Eric-ADK
    Tech Manager
