Activity Forums Adobe After Effects After Effects CS6 dynamiclinkmanager.exe Error
  • After Effects CS6 dynamiclinkmanager.exe Error
    Posted by Viktor Voscek on April 29, 2016 at 5:11 pm
    Hello,
    This is my first time posting here, and sorry for my english
    I have problem with After Effects on startng. Everything loads and then it gets stuck at the “Intializing user Interface” and 2 minutes after it gives me error [link below]
    I´ve tried everything; re-installing 2 times, downloading dynamiclinkmanager.exe from others users, set folder privileges and literally every “fix” from YouTube and other forums. And it still giving me the same error. I dont have Quicktime installed,I dont have any plug-ins I have turned off all visual setting in Windows because my computer is slow. Could that be the problem?
    Error: https://gyazo.com/c6da388b3a3a66b290c165ec006d997e
    Voscek
    Amateur editor, still learning alot :3
    Viktor Voscek replied 10 years, 1 month ago 2 Members · 3 Replies
  • Walter Soyka
    May 1, 2016 at 10:25 am
    Re-installing doesn’t reset preferences. Try that, for both Ae and Premiere. Hold Ctrl+Alt+Shift (Windows) or Command+Option+Shift (Mac OS) while the application is starting.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Viktor Voscek
    May 1, 2016 at 11:03 am
    What is supposed to happen? Because application was starting normally and still the same error appears. Also I deleted preferences manually after uninstall.
  • Viktor Voscek
    May 1, 2016 at 11:14 am
    Nevermind got it to work, deleted preferences but it still giving me the same error :/
