Activity Forums Adobe After Effects after effects cs6 crashes on startup
  • after effects cs6 crashes on startup
    Posted by Eli Magaziner on October 28, 2013 at 10:28 pm
    this is the error message i get every time I try to start AE CS6, for several days now. (mac)
    at first I thought it’s because i tried to mess with the presets.xml file (because one of the plugins needed an edit there), but after I tried installing and uninstalling several times now (and checked that the file was reset), I kinda gave up. (I also tried removing the magicbullet plugins, following a tip from adobe forums)
    I really need help guys, my job is on the line here
    thank you
    Eli Magaziner replied 12 years, 10 months ago 2 Members · 2 Replies
  • Ridley Walker
    October 28, 2013 at 10:50 pm
    Three things I would try:
    1) Reset the preference file to default settings by holding down Shift+Option+Command as you launch After Effects.
    2) Permissions repair using Disk Utility.
    3) Making sure you have the latest After Effects updates installed.
  • Eli Magaziner
    October 29, 2013 at 5:53 pm
    thanks for the help, but none of those worked…
    I actually did find the solution!!!!
    IT WAS THE FONTS. i turned off some of the fonts in Fontbook,
    and apparently they’re REALLY important to after effects.
    hope that helps for the rest of u 2
