Activity Forums Adobe After Effects After Effects CS6 camera solve to C4D not aligned properly
  • After Effects CS6 camera solve to C4D not aligned properly
    Posted by Larry Chadwick on May 30, 2013 at 7:45 pm
    Hello!
    I am currently working on sending camera tracker data from AE CS6 into C4D R14 for 3D work.
    I have sent multiple projects over from AE with no problem, but now I’m having an issue with a camera tracker.
    I shot a desk surface, which wasn’t a lock off.. (take a look at my icon) just a some movement where I rotate around the desktop a bit. I solved the camera, and nulls,solid, texts are locking to the surface.
    When I send the camera over to C4D r14, it is way out of whack. Even without adding a background layer (with the orig video clip) I can tell it is orientated wrong.
    I’ve tried to put objects, the camera, and then sometimes both in a null and try to line it up with the clip.. but its not working very well
    Is this a known issue? I do understand there are corrective steps to be taken sometimes with a solve like this. All the video tuts. I’ve found have simple shots/tracks that line right up in C4D, but nothing with camera rotation around a plain like I have.
    Thanks in advance!
    Vladimir Lester replied 7 years, 11 months ago 3 Members · 4 Replies
  • Larry Chadwick
    May 31, 2013 at 2:10 pm
    Thanks Dave!
    I did render it out, and technically it is lining up, but I’ll clarify the issues I’m noticing.
    To your point about the origin data, that is the first issue. The 2 solids I placed in AE on the surface to translate over to C4D are there, but not centered on the C4D origin (0,0,0) to get objects to stick to the plain i want to track onto, I have to move them over and rotate them.. I’d love to find a way to flatten out the scene (with camera of course) so new objects pop in where they need to be.
    Screen shot: shows the plains, and the C4D origin:
    Secondly, I dropped some objects in and rendered them out, but now they are slipping off the track in AE.
    I need to triple check the aspect ratios, and frame rates.. but it looks like it is floating above the tracked surface.
    Helmet Table Track
    Thanks for the help.
    Larry Chadwick
    Video/Finishing Editor
    Pluto Post
    hellopluto.com
    larrychadwick.com
  • Chris Schoenmaker
    June 4, 2013 at 7:37 am
    Hi Larry,
    Did you have any luck sorting this one out? I’m having the same issue, the only difference is I have C4D r12. Everything seems correct however I have noticed the rotation coordinates in C4D are the opposite of what they are in AE (CS6).
    If anyone knows the answer to this dilemma please let us know.
    Thank you,
    Chris.
  • Larry Chadwick
    July 24, 2013 at 1:35 pm
    No I havent found a solution yet. It has to exist out there, we couldnt be the first people to want to solve a camera in after effects and round trip with C4D.
    I’ll end up doing camera solves with pf track and nuke to get the results I’d like to achieve.
    Larry Chadwick
    Pluto Post
    hellopluto.com
    larrychadwick.com
  • Vladimir Lester
    September 8, 2018 at 1:50 pm
    I’ve had this problem over a straight year and NOT A SOUL can help. Or they just ignore it because they can’t fix it. I’ve gotten over 30 views on my exact same post and NO ONE has answered. Any resolution yet?
