Activity › Forums › Adobe After Effects › After Effects CS6 – 2 problems
  • After Effects CS6 – 2 problems
    Posted by Rob Chan on June 14, 2012 at 3:32 pm
    Hi everyone
    I’m suffering with 2 problems since my upgrade from CS5.
    1. I get the Error 5070 on Start up even though I have a Quadro 4000, I’ve been on the Adobe forum but none of the advised actions have solved the problem, is anyone else still getting this since the 11.01 update?
    2. I thought I’d put a project through CS6 to see how the render times might change. The project rendered in CS5 took around 45mins. However in CS6 this has increased to nearly 3 hours!
    The project consists of mainly motion graphics, a few referenced .MXF files in 3D space, a tint bit of Trapcode 3D stroke and a Dynamic Link to Premiere.
    here’s my set up…
    Mac Pro 3,1 (2x 2.8GHZ)
    20GB RAM
    OS 10.7.4
    NVIDIA GeForce GT8800
    NVIDIA Quadro 4000 both on GPU Driver 207.00.00.f06
    CUDA Driver 4.2.10
    As for the slow render
    Files are on a 2TB (7200rpm)
    Rendering to a 1TB (7200rpm)
    60GB SSD Cache
    Any help would be gratefully received.
    Rob
    Rob Chan replied 14 years, 3 months ago 2 Members · 6 Replies
  • Darby Edelen
    June 15, 2012 at 4:44 am
    Are you using Render Multiple Frames Simultaneously in CS6? What are your settings in that preference pane?
    Darby Edelen
  • Rob Chan
    June 15, 2012 at 10:52 am
    Hi Dave
    Yes all NVDIA drivers are up to date – I’ve even tried rolling back and trying some previous versions as well but to no avail.
    Hi Darby
    Yes Multiprocessing of Frames simultaneously is set to ON as it was in CS5, in fact I’ve just copied the stable settings I used in CS5 to CS6 – which is why I’m puzzled to the slow render times.
  • Rob Chan
    June 15, 2012 at 12:19 pm
    UPDATE: Just re-rendered with Multiprocessing of Frames simultaneously OFF and it has rendered in 40mins. Ok so that problem seems to be solved. Thanks!
  • Darby Edelen
    June 15, 2012 at 4:24 pm
    Just double checking. You have the NVIDIA CUDA Driver for Mac in addition to the regular drivers?
    https://www.nvidia.com/object/mac-driver-archive.html
    Darby Edelen
  • Rob Chan
    June 15, 2012 at 4:41 pm
    Hi Darby
    Yes I have the latest CUDA driver as well as the latest driver for my card.
    I have tried a couple of previous forms of the driver as well.
    Any other suggestions would be great
  • Rob Chan
    June 19, 2012 at 4:34 pm
    Success
    Due to desperate measures to resolve the problem.
    I freshly installed Lion, NVIDIA, CUDA and CS6 onto a new SSD.
    This got rid of the 5070 Error and enables me to use Ray Tracing.
    When I get some downtime I’ll use Carbon copy to clone my old drive but without and Adobe or NVIDA files to see if that makes a difference.
    r.
