Activity › Forums › Adobe After Effects › After Effects CS5.5 can’t render in QuickTime. Tried it all.
  • After Effects CS5.5 can’t render in QuickTime. Tried it all.
    Posted by Connor Chaz on February 16, 2013 at 12:32 am
    I’m trying to export a project in .mov but I continue to get this error:
    https://gyazo.com/c8e45e837b19b9a7129bdc3b27e26627
    Not to mention I can’t import .mov files either, every time I import After Effects crashes. I have the latest version of QuickTime also. I’ve never had this problem before but I went a good bit of time without using the After Effects, it’s apparent something has changed because I’ve never had this problem prior.
    I’ve tried reinstalling/uninstalling After Effects; did the same with Quicktime.
    Here are my computer specs:
    https://gyazo.com/0cae79dd5940611b9f716faf53682d1a
    Thank you in advance!
    Martin Olsen replied 12 years, 5 months ago 4 Members · 4 Replies
  • Todd Kopriva
    February 16, 2013 at 4:52 pm
    See this:
    “troubleshooting QuickTime errors with After Effects CS5, CS5.5, and CS6”
    After Effects team blog
  • Connor Chaz
    February 17, 2013 at 7:01 am
    Hmm. Well after trying everything, I had had it all. I ended up re-installing my operating system. Then using disk cleanup to remove all older versions of windows. Hope others find the answer quicker than I did, but if all else fails you can always reboot your system!
  • Tom Daigon
    February 17, 2013 at 3:15 pm
    In my case doing a clean reinstall of Win 7 did not solve the problem.
    Following Todd’s advice about computers that have lots of hyperthreads cleared up my issues.
    Tom Daigon
    PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    https://www.youtube.com/watch?v=DxPrG3WUyz8
    (Best viewed at 1080P and full screen)
    HP Z820 Dual 2687
    64GB ram
    Dulce DQg2 16TB raid
  • Martin Olsen
    April 18, 2014 at 12:02 am
    I had originally received this error while trying to export a quicktime animation.
    (An output module failed. The file may be damaged or corrupted. (-1610153464)
    and this error when trying to import .mov files (“.mov file is damaged or unsupported”)
    After lots of different attempts to fix the problem I found out that my virus scanner(bitdefender) was some how blocking my quicktime codec. After uninstalling bitdefender this fixed both my problems of importing and exporting.
    So maybe try turning off your firewall or antivirus for a bit and see if that fixes your problem.
