Activity Forums Adobe After Effects After Effects CS3 Timewarp effect
  • After Effects CS3 Timewarp effect
    Posted by Rob Thomas on January 29, 2008 at 6:18 pm
    Hello all in the digital world! I’m a, somewhat beginner with AE and am having an issue with the Timewarp effect. I have video shot on a green screen. I’ve used Keylight to remove the screen and a mask to remove other unwanted portions. When i apply the Timewarp effect, the Keylight and the mask stop working. Is there something i need to enable or do? Thanks for any/all help!
    Jean-louis Frisee replied 18 years, 7 months ago 4 Members · 3 Replies
  • Darby Edelen
    January 29, 2008 at 7:54 pm
    Don’t apply timewarp to the layer with keylight applied. Instead pre-comp that layer (select it and press cmd-shift-c/ctrl-shift-c), move all attributes into the pre-comp and apply timewarp in the parent composition.
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • David Bogie
    January 30, 2008 at 3:06 pm
    Or pre-render the matte output and apply timewarp to the movie.
    bogiesan
  • Jean-louis Frisee
    February 6, 2008 at 11:58 am
    talking about pre-render, wich format/codec would you advise to avoid loss of quality ? I am usually working with dv pal rushes and i don’t know if i have to pre-render with quicktime animation (very heavy) or if quicktime DV is enough and will not destroy my file…
