Activity Forums Adobe After Effects After Effects Crashes?
  • After Effects Crashes?
    Posted by Isaiah Bugarin on August 5, 2011 at 3:48 pm
    For some reason, AE crashes whenever I load my project file. I’ve gotten any number of errors from telling me that my “Language could not be identified from registry: [path]. Deaulting to en-US.” to saying “Unable to invoke LF Glow”. This problem only seems to occur when I put any Knoll Light Factory FX anywhere on my composition (i.e the clip itself, a new adjustment layer, etc.). I have to be done with the editing of this clip by tomorrow and I need AE to quit crashing when I put Knoll Light Factory in it. Does anyone know how to fix this?
    Isaiah Bugarin replied 15 years, 1 month ago 2 Members · 3 Replies
  • Isaiah Bugarin
    August 5, 2011 at 4:19 pm
    Your computer: Windows 7 x64, Intel Celeron 925 @ 2.3 GhZ, 3 GB RAM, 70 GB available on HDD.
    Your version of After Effects: 10.0.10.4
    The media container (avi, qt, etc.) and the codec of your footage: WMV Raw, and MOV Sorenson Video 3
    Whether you’re trying to use multiprocessing or not: I haven’t touched any settings about multiprocessing so I’m guessing no.
    Whether you’re trying to use Open GL when rendering or not: I don’t know how to find this out. Same as above.
    The method you used to install the Knoll plugins: I installed the trial then activated it.
    Any third-party codec packages you’ve installed: Not to my knowledge.
  • Erik Waluska
    August 6, 2011 at 7:43 pm
    Some AE problems can be solved by deleting the preference file.
    Restart AE while holding down the Command + Option + Shift keys (Mac) or Control + Alt + Shift (Windows), and you are presented with an option to delete the preferences.
    Also, try to remove the plug-in and start AE and see if that’s the problem. If so, try reinstalling it and see if that helps.
  • Isaiah Bugarin
    August 6, 2011 at 9:59 pm
    I deleted my preference file, but it still gives me an error whenever I try to put any Knoll LF FX in my composition. I already tried reinstalling it, and that didn’t work either.
