Activity Forums Adobe After Effects After Effects crashes when I open comps, but not always…
  • After Effects crashes when I open comps, but not always…
    Posted by Ian Dillon on November 5, 2020 at 6:37 pm
    I have a new MacBook Pro with latest version After Effects. I’m trying to work on a project from my older MacBook Pro that had a slightly older version of After Effects. I can open comps a couple times then I get a crash when opening them. It can even be a comp that I just had open. I’ve tried all the standard clearing caches, RAM, switching to software only rendering, etc. I’m stuck and can’t work more than 5-minutes at a time now because it crashes. HELP PLEASE. I have attached the crash report.
    Dave Baum replied 5 years, 10 months ago 2 Members · 2 Replies
  • Dave Baum
    November 5, 2020 at 6:47 pm
    Hi Ian,
    You could try:
    A – New project and import the problem comps, save as new file.
    B – Try to open problem comp / project, and when you get a successful go (you mentioned it doesn’t always crash), then copy and paste the contents of the problem comp into a brand new comp. Then delete the problem comp and save as new project.
  • Dave Baum
    November 5, 2020 at 6:48 pm
    Might also be helpful to say what is in the comp – is it footage with wrong frame rate for example, or something with a complex expression or an out of date plugin or script?
