Activity › Forums › Maxon Cinema 4D › After Effects Composite shadow for a Rigid Body simulation using Instance
  • After Effects Composite shadow for a Rigid Body simulation using Instance
    Posted by Michael Garske on March 2, 2014 at 5:32 pm
    R15 Studio
    AE 12.2.1
    I have a floor with a collider body tag and an object with a rigid body tag. I’m trying to composite the shadow of the rigid body object in After Effects using an instance as the shadow caster. But when I apply the rigid body tag to the instance to replicate the simulation it’s interacting with the object itself causing the two to bounce off one another.
    Is there a way for me to exclude the instance shadow caster from interacting with the actual object? Am I going about this entirely the wrong way?
    I’m very new to Cinema 4D so thanks so much for your time and knowledge!
    Michael Garske replied 12 years, 7 months ago 2 Members · 3 Replies
  • Adam Trachtenberg
    March 2, 2014 at 5:44 pm
    I don’t understand. Why are you using the instance object instead of just rendering out a shadow pass?
  • Michael Garske
    March 3, 2014 at 12:28 am
    I saw a tutorial recommending that I use instances to single out shadows in AE.
    Thanks for the advice for multi-pass output. I was able to bring a shadow layer into AE using multi-pass but the shadows aren’t displaying correctly in AE for some reason. Here are a couple of screen shots for my scene setup if it helps.
    I know I can get the shadow back if I put the floor and bone on the same layer but then I won’t be able to composite the shadow separately.
    It looks like the Global Illumination is rendering differently as well. I’m brand new to this workflow so I’m not sure what I could be missing. Thanks again!
  • Michael Garske
    March 3, 2014 at 4:51 am
    I figured it out. I just needed to set one cineware layer in AE with both the floor and object to a shadow pass. Thanks again!
