Activity Forums Adobe After Effects After effects CC render problem
  • After effects CC render problem
    Posted by Vipati Hitesh on July 23, 2013 at 11:33 am
    Hello All,
    I have problem with After Effects cc Render. Actually, I go to File > New > Maxon C4D files. Then, I created & animated a cube in C4D lite. When I go to Composition > Pre render & save it, it is rendering C4D grid also. I want to render that cube only. I don’t want to render that grid. I turn off Grid option in C4D even though it’s showing in AE CC & render as well.
    Please see below snapshot :
    I want to remove this grid & keep only the cube. Please help me how to do this??
    Vipati
    Vipati Hitesh replied 13 years, 2 months ago 2 Members · 4 Replies
  • Todd Kopriva
    July 23, 2013 at 2:14 pm
    Show a screenshot of your settings in the Cineware effect in After Effects. I think that you have it set to Software (draft).
    I recommend going through the information about this feature:
    https://blogs.adobe.com/aftereffects/2013/04/details-of-cinema-4d-integration-with-after-effects.html
    After Effects team blog
  • Vipati Hitesh
    July 23, 2013 at 4:01 pm
    Hello Todd Kopriva,
    Please find below snapshot of cineversity settings in AE CC :
  • Todd Kopriva
    July 23, 2013 at 4:48 pm
    It is as I guessed. You have the Renderer set to the draft Software mode.
    Be sure to go through the details in the post that I linked to so that you understand how this feature works.
  • Vipati Hitesh
    July 23, 2013 at 5:00 pm
    Hello Todd Kopriva,
    Thanks for your replay. I checked the link given by you & I came to know that I have to change Renderer from Software to Standard(Final).
    My problem is solved.
    Thanks again,
    Vipati
