Activity Forums Adobe After Effects After Effects CC 2015 no motion blur
  • After Effects CC 2015 no motion blur
    Posted by Joe Skillington on December 21, 2015 at 10:09 am
    Hi I have searched for a post that deals with this issue but couldn’t find anything – apologies if it is out there, I am new here!
    I am trying to get motion blur to work on Adobe After Effects 2015. I have the appropriate layers motion blur switched on and and the ‘master motion blur’ active. I have my selected layer moving (at speed) from left to right of screen. This isn’t video of motion this is actual key-framed movement. There is no blur occurring. I have the previews at full (no wireframe etc) but still nothing.
    Anyone have any ideas – am I missing something obvious?
    Thanks in advance and again, sorry if this has been covered somewhere,
    Joe
    Andrew Jehan replied 6 years, 11 months ago 3 Members · 5 Replies
  • Kalleheikki Kannisto
    December 21, 2015 at 12:22 pm
    Do you have effects applied to the layer? Some effects do not support motion blur, in which case you can use CC Force Motion Blur.
  • Joe Skillington
    December 21, 2015 at 12:44 pm
    Thanks for your response. I don’t have any effects applied but I will give the CC force motion blur a try and let you know how I get on!
    Thanks again,
    Joe
    Here to help if I can
  • Joe Skillington
    December 21, 2015 at 8:04 pm
    Thanks! It was the shutter angle – it was set too low.
    Much appreciated,
    Thanks again,
    Joe
  • Andrew Jehan
    October 2, 2019 at 2:00 pm
    I’m having this problem right now. I know about “force motion blur”, but I’d like to figure out what’s causing this issue. It’s a very fast position transform on a precomposed text layer, see screenshot.
  • Andrew Jehan
    October 2, 2019 at 2:12 pm
    For people reading this thread in the future, I figured it out. Apparently having the ‘collapse transformations‘ switch on stops the motion blur from working. If you need collapse transformations on, then you need to use ‘force motion blur‘.
