Activity Forums Adobe After Effects After Effects Audio Problems
  • After Effects Audio Problems
    Posted by James Hoback on May 27, 2010 at 2:18 pm
    I’m rendering a 1 minute compositions with audio tracks mixed in my time line. When I preview my audio in the comp, everything sounds fine, including all my cross fades.
    When I render it as an H264 for client review, the picture looks fine, but the audio is messed up. Any where there is a cross fade, instead of being clean, the audio dips in volume.
    I’ve tried everything and it is driving me nuts. Any advice would be much appreciated. Thank you.
    James Hoback replied 16 years, 4 months ago 33,947 Members · 2 Replies
  • James Hoback
    May 28, 2010 at 12:38 pm
    Thank you very much for your advice. I’m always confused by this, because what I’m animating is driven by a music mix. As I worked with the client, we would come up with different ideas for the music mix and voice over placement, so it all had to be done in After Effects. I’m not quite sure how other people manage to accomplish the final mix.
  • James Hoback
    May 28, 2010 at 3:20 pm
    Dave, thank you so much. I took your advice and rendered each audio clip separately and wrote down the time code for the cross fades.
    Thanks again. Take care.
