Activity › Forums › Adobe After Effects › After Effects applies effect to entire source clip
  • After Effects applies effect to entire source clip
    Posted by Chad Britton on September 12, 2013 at 10:07 pm
    My job just made the move to Adobe editing software and I’m having some issues with After Effects. I work on football highlights so my source clips are very large .MTS files which contain an entire quarter of football each. When I apply an effect to a single clip, in this case the shatter effect, it applies it to the entire source. So the shatter will happen right at the beginning of the source clip, and the part of the clip I want, and any other clip using that source video, will be shattered already. That’s not how it works in Premiere at all so I have no idea why it is like that in After Effects. Any advice?
    Chad Britton replied 13 years ago 2 Members · 2 Replies
  • Mathew Fuller
    September 12, 2013 at 11:16 pm
    Mr. LaRonde
    It’s actually ctrl-shft-D or cmd-shift-D to split a layer.
    My Work:
    https://www.morecompletefx.com
  • Chad Britton
    September 13, 2013 at 12:58 am
    I used the split method and was able to isolate the clip so that the effect only applied to it. However, I still ran into the same problem with the effect starting at the beginning of the source clip. Like if you double-click the clip, it shows the entire source video in the display and I can see the effect happening right at the beginning. Usually with basic effects I’d be able to fix this with a couple keyframes, but the shatter effect is pretty convoluted and doesn’t really have a way to set when the shatter occurs.
