Activity Forums Adobe After Effects After Effects 7.0 Ram Issues
  • After Effects 7.0 Ram Issues
    Posted by Azoitas on June 29, 2006 at 6:19 pm
    Hello, I am running a Apple G5 Quad 2.5 with 4.5 GB of Ram and I have recently just purchased and installed the latest version of After Effects.
    When I check system profiler it reads that I have 4.5 GB of Memory.
    But when I Launch after effects, it states i have 3.0 GB of Memory.
    I do not know why this happens. But I need help!
    Thanks in advanced.
    -Azoitas
    Tim Kurkoski replied 20 years, 2 months ago 2 Members · 3 Replies
  • Tim Kurkoski
    June 29, 2006 at 7:36 pm
    This is normal. Although Mac OS can use a lot of RAM (16GB? I forget the max), it can only allocate about 3.5 GB of RAM to each application. And more of that is lost to OS overhead, so your effective RAM allocation per application is about 2.5-3 GB.
    So what’s the point of having more than 4 GB if that’s the case? Mac OS can allocate 3 GB of RAM to EACH application, so you could have Photoshop, AE, FCP, and other apps open at the same time using 3 GB RAM each, as long as you have enough RAM for all to take the maximum.
  • Azoitas
    June 29, 2006 at 11:16 pm
    This makes sense, I had no idea that OS X has done this, is it the same with a Windows Based PC?
  • Tim Kurkoski
    June 30, 2006 at 6:01 am
    Yes, though Windows is limited to 2 GB per app. There is a way to increase it to 3 GB, but it can potentially cause stability issues. The 64-bit version of Windows has a much higher limit, but very few applications are written for 64-bit.
