  • Posted by Verita on December 17, 2006 at 4:54 am
    hello creative cows,
    I would be happy about getting tips for this problem:
    I try to circle an object (planetball) with keyframes in xyz-position manner.
    Can’t find solution between the first and last keyframe to get a loop without
    getting a visible break between start and end of movement in my ramshow.
    I don’t know do I need expressions, because about this I have very little
    knowledge?
    Thankyou for every tip
    with best greetings
    verita
    Verita replied 19 years, 9 months ago 4 Members · 5 Replies
  • Colin Braley
    December 17, 2006 at 6:14 am
    Just make sure the position value of your last keyframe is equal to that of your first keyframe. Then apply the following expression:
    loopOut(“cycle”)
    ~Colin
  • Mike Clasby
    December 17, 2006 at 6:18 am
    If you have one revolution keyframed, and the first and last keyframes are the same you might try this loop expression:
    loop_out(“cycle”,0)
    But to get circular movement without keyframes, expression only, try this expression on position by Dan Ebberts (there are other expressions but I think this is the most controlable):
    r = 50; //radius (in pixels)
    f = 1; //orbits per second
    angle = time*Math.PI*2*f;
    value + [Math.sin(angle)*r, -Math.cos(angle)*r]
    Just change the radius and orbit per second to taste.
  • Steve Roberts
    December 17, 2006 at 11:40 am
    … and you should set your work area to end 1 frame before the loop starts again.
    For example, if frame 0 is the same as frame 50, the last frame of the work area should be 49.
  • Verita
    December 19, 2006 at 1:39 am
    hello steve,
    my first step to a forum.
    Thank you much.
    I’ve got blind of checking and after reading your
    message I could therefore finalley find my mistakes.
    Two mistakes, forgot realley this time-management
    and made instead curious things … (forget about)
    Wish you a very good ending year with best with best
    2007 wishes
    Verita
  • Verita
    December 19, 2006 at 5:02 pm
    [verita] “hello steve,
    Thank you much.
    Wish you a very good ending year with best 2007 wishes
    Verita”
    Thank you much.
    2007 wishes
    Verita”
