Activity Forums Adobe After Effects After Effects 3D shape positioning??
  • After Effects 3D shape positioning??
    Posted by Eddy Elliott on February 25, 2014 at 10:54 am
    Hi guys, really need your help on this one!
    I’m relatively newish to After Effects but not a complete novice. My question is this…
    I’m trying to build a large Typography “scene/ set” within After Effects, which I then want to animate the camera around. Whilst adding new elements to the scene such as text or a square/ ellipse, I’ll pan the camera over to the desired position, draw a new element in place, but then when I click the “enable 3D” button for the layer, the object disappears back to the original centre of the entire composition, which means I then have to parent the layer to the camera, reset the position, un-parent the layer to get the object back to where it was intended.
    Is there a way to draw a shape layer/ text in its intended 3D position (on the active camera’s focal plane) without having to go through the repositioning drill each time?
    Many thanks guys!!
    Eddy Elliott replied 12 years, 6 months ago 5 Members · 8 Replies
  • 8 Replies
  • Daniel Waldron
    February 25, 2014 at 1:09 pm
    I would use a Custom view to see your 3D scene, including your camera, then position your text or other assets. For a helpful camera control tool, you can check out the SureTarget plugin on Video Copilot.
  • Eddy Elliott
    February 25, 2014 at 2:12 pm
    Thanks for the reply Daniel, but I have the same problem using a custom cam.
    I’ve attached a screen grab of the style of infographic I’m trying to create.
    It’s quite complex and I need to be able to build and add shape layers and text in position as I go along.
    But every time I add a new element and convert the layer to 3D, the layer re-centers itself way back at the start of the composition.
    Many Thanks.
  • Walter Soyka
    February 25, 2014 at 2:53 pm
    If you press Ctrl+Home (PC) or Cmd+Home (Mac), it will center the selected layer(s) in the active view.
    Walter Soyka
  • Matt Davis
    February 25, 2014 at 3:10 pm
    Whether or not that answered Ashley’s question, it was something that I didn’t know before.
  • Eddy Elliott
    February 25, 2014 at 3:23 pm
    Walter.. that is absolutely brilliant!! Thank you SO much, that really has made my day! 🙂
    One more related question… Once the selected layer is centred in the active view, is there a way to tell the layer to face the camera?
    (Using “Transform – Auto-Orient” seems to make the layer permanently stick to the camera)
    Thanks again!!!
  • Walter Soyka
    February 25, 2014 at 8:17 pm
    I had been meaning to write a script to make this easier for quite some time.
    Here it is:
    https://www.keenlive.com/renderbreak/2014/02/after-effects-script-center-layer-in-active-cameras-view/
    Walter Soyka
  • Roland R. kahlenberg
    February 26, 2014 at 1:51 am
    Another useful shortcut key is CTRL+ALT+SHIFT+\ – Look at Selected Layers (found in the View menu. This works well when you’ve placed a 3D layer in its place and want your camera re-positioned to view the layer, centered in the Comp Panel.
    With CTRL+HOME, you move the selected layer(s) to the Comp Center, probably after you’ve moved/animated your camera. With CTRL+ALT+SHIFT+\, you move/animate the camera instead of the selected layer(s).
    HTH
    RoRK
    Latest AE Workshop – MoGraph Intensity – Shapes & Text
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE/ACI
  • Eddy Elliott
    February 26, 2014 at 10:19 am
    Walter… Wow! That script is absolutely fantastic! Thank you so much, you’ve been such a great help. If you’re ever in London UK give me a shout anytime, I definitely owe you a pint 😉
    And thanks to Roland too, that’s another really handy little shortcut…
    You guys rock! 🙂
