Activity Forums Adobe After Effects After effect: Use anchor point for center of an effect expression
  • After effect: Use anchor point for center of an effect expression
    Posted by James Spadafora on May 16, 2013 at 2:29 pm
    Hello I have an animated object inside of a comp that has a anchor point that I would like to use as the center point for a radial blur.
    the structure is: mapsComp -> myObject -> the anchor point.
    What expression would grab this anchor point. I tried
    thisLayer.layer(2).anchorPoint;
    But that seems to not be working. Any ideas?
    Ridley Walker replied 13 years, 3 months ago 3 Members · 3 Replies
  • John Cuevas
    May 16, 2013 at 3:22 pm
    Why can’t you just pick whip to the anchor point?
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • James Spadafora
    May 16, 2013 at 3:38 pm
    Can I do that if I need the value from a nested comp?
  • Ridley Walker
    May 16, 2013 at 4:19 pm
    You can open two Timeline panels, one for each and pick whip between them.
